Send function not working on CS-1820. Result "NG" - no error specified other than "error occurred." This happened once before, a couple years ago, but I do not remember how to specifically fix the problem. I believe more memory needed to be allocated to the scanner function, but cannot figure out how to do that. It will scan a page and a half, but locks up during the second page and gives the error.
Try to if you will have a fuser error make sure you have the top cover open when you
turn on the machine. They neglect to tell you that in the manual.
Keep in mind that the machine must be set up via LAN in order to scan. It scans via SMB
protocol. Once set up on the network enter the IP address into internet
explorer, click the basic tab and select the address book, and you will
see the interface to configure.
Hope this helps.
Http://usa.copystar.com/americas/jsp/Kyocera/contactus.jsp
You can contact Kyocera Copystar about this problem at the above web address form or,
1-800-255-6482 Mon. through Fri. 9AM -6PM EST. Technical Support.
I searched for the more memory needed to be allocated in their FAQ's but didn't find any reference.
I think that when power goes out, the memory can be lost on the copystar device. Is that not true?
So, it could be a software issue, as far as reprogramming the copystar copier to scan correctly.
If more memory has to be allocated to the function, then it is a software issue. I believe this to be the case.
Thanks for the help - turns out it was not a memory issue (the last repairman we had come out may have been fixing two problems).
so you solved the problem, already? (according to one of your comments)
Yes, I solved the problem. I tried updating the status of this question to reflect that.
I will advice you uninstall the software and reinstall back, sometimes when a scanner stops working or when the scanner is not scanning properly, you can get
it to go again by reinstalling. To do this, first disconnect your
scanner from your computer, then uninstall the software that came with
your scanner. Next, reconnect your scanner and follow the instructions
to reinstall the software. This should fix the problem.
Take care.
This is not a software issue. Happened after thunderstorms took out the power at our office for a few hours one night.
No fuser error. Just double-checked all email settings and it is configured properly.
No software to uninstall/reinstall. The scanner is setup on a network to email - not directly connected to my computer.
In the Command Center (which I accessed by entering the printer IP in a browser), I had to update the DNS server and changed the email server name to the server IP and it fixed the problem.
