Question about Whirlpool Duet GHW9150P Front Load Washer
What do you do when SUD is flashing on the front. It is a Whirlpool Duet Washer about 4 yrs old.
    New Friend:
  • 13 Answers
Here's two links on the SUD error on a Whirlpool Duet--pretty common with these newer front load washers--try less soap, try different soap, check the pressure switch.....
http://www.managemylife.com/mmh/questions/148082-what-is-causing-f02-and-sud-to-display-on-my-whirlpool-duet-washer
http://www.managemylife.com/mmh/questions/151612-why-does-my-whirlpool-duet-washer-flash-an-sud-message-followed-by-a-f35-code
Posted on Jul 16, 2010
    Scholar:
  • 79 Answers
Outside the normal analog pressure sensor (APS) / hose checks...
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See http://www.f35error.com for more information.
I hope this helps and let me know if you have any more questions.
Posted on Jul 10, 2015
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will rotate to balance
To solve this:
  • If the above does not correct the problem, replace the pump.
thanks.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flases F and sud and will not drain
your using to much soap front loaders use 2 table spoons of soap and maker sure it's HE soap
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,431 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
