I have a brother DCP-110C printer and I have just replaced the black and yellow ink cartridges and it says they are still low and are not actually printing anything. The ink isn't coming our on the page... can you help?
Thanks
Gemma
See If you're facing issue of brother printer not printing, then you must follow all these steps to get rid out of these prolem!
1.Check the interface cable on both printer and your computer
2.Check if your printer is plugged in and not in power save mode
3.Check to see if the LCD is showing an error message
4.If the LCD says cannot print and replace ink, replace the ink cartridges
5.Check if the correct printer driver has been installed
6.Make sure that the machine is online. Click start and then printers and faxes. Choose Brother MFC-XXXX where XXXX is your model name and make sure that use printer offline is unchecked
7.When you choose print odd pages and print even pages settings, you might see a print error message on your computer because the machine pauses during the printing process. The error message will gradually disappear after the machine re-starts printing
If you still stuck then visit this trusted site: Brother printer not printing
Toll-Free No: +1-888-633-7151
The all in one printer that uses ink for printing might operate by dropping various sized liquid ink drops into the paper offered to it. Various issues might occur while using these all-in-one printers like printer not working, the color printer not printing yellow color etc. These might be caused due to driver issues, lack of ink in printers, hardware issues etc.
Get more information to fix Brother Printer Not Printing . Hope this information helps you.
Clean the heads....................
found in printing preferences / maintainance
