SOURCE: KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls everything...one sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
SOURCE: Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
This refrigerator has other design problems, which Kitchenaid refuses to address...Does your ice maker spill ice all over the inside of your freezer because of the gap at the back of the bin? Constantly hearing the clitter clatter of falling ice inside the freezer and having to pull everything out to remove all the pieces from the bottom of the freezer became such a nuisance my husband finally duct taped a piece a plastic to the bin to fill the gap. I won't buy another Kitchenaid anything because they wouldn't fix the problem.
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
