REFERRING TO 'OPERATING INSTRUCTIONS'.........
0OOOOOOO THEN GOES T F60 CODE
DISC WILL NOT EJECT
NO 'POWER LITE' AND REMOTE WILL NOT FUNCTION
NO RESPONSE WITH DVD EJECT BUTTON
NO RESPONSE TO HOLDING POWER BUTTON MORE THAN 10 SECONDS.
HAVE DISCONNECTED PLUG SEVERAL TIMES WITH NO RESULTS
NO RESPONSE TO HOLDING SIMULTANEOUSLY 'PAUSE' AND 'CHANNEL UP' BUTTONS
NO MORE TROUBLE SHOOTING TIPS IN MANUAL
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Turned the power off for 10 mins. and pressed the power button it cleared the F60 code.
