Make sure that the TV is on the right setting, either TV for analog pictures, or DTV for digital. Run a complete auto-setup. This will wipe the tuner memory and re-scan. Hopefully this should sort the problem. If you have tested the aerial cable with another TV in place of that one (not just on a cable from the same aerial in another room) and it works but that one won't, then it will be down to a TV fault. If this helps, please rate me!
