I need to find the setup codes for an Akai KC01-B2 to operate by a comcast remote. The codes listed in the comcast guide do not work. Also found reference to substitute Samsung remote setup codes and that does not work either. Thanks. Steve
[email protected]
I need to finde a code for a comcast remote using the AKAI T V
Please help, and thanks so much
Most remotes of that type have a "Code Search" feature, and it's the easiest way to find the code. You would put the remote in search mode (following the remote's instructions) and run through the codes 1 at a time, if you see the Unit turn off, you store the code. If that doesn't work, then the remote simply won't work for that Unit.
Hope that fixed ya...
Geno
Thanks for your help GENO, I will try it! Much Appreciated
