You may take off formatter board and put in oven with aluminium foil and cook for 4 minutes. Than take out from oven make a cool down about 15 min. Than put back in. Turn on printer it will work. :)You may take off formatter board and put in oven with aluminium foil and cook for 4 minutes. Than take out from oven make a cool down about 15 min. Than put back in. Turn on printer it will work. :)
You can't post conmments that contain an email address.
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode. Comment if you need additional assistance.
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
