Yes. See pages 67-68 of this manual.
SOURCE: Internal memory to memory card
Generally, it's not possible to move images from internal memory to a memory card, which poses a problem because you can't connect that camera to your computer.
Most digital cameras keep the internal memory separate from the memory card. Not sure why, but they do.
It's unlikely that you'll be able to get those photos off, if the camera isn't recognized by the computer.
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
SOURCE: Is there a way to transfer photos saved in
Try by removing the memory stick and then attaching the camera to
computer with USB cable. Switch on camera. It should open up a dialogue
box in Windows XP (or similar OS). Select 'open folder to view file' or
open Windows Explorer and open camera folder (probably displayed as new
drive E: or like that in My Computer) . You may also check whether
there is an option of selecting "camera as mass storage device" in
settings menu of camera. If yes then select this before connecting.
If you have no means of attaching the camera to the computer, place
an empty memory stick into the camera. In review mode, a message
indicates there is no data, but there is in the internal memory. While
still in review mode, press the menu button and go the the "Setup"
section, the last option. Now, scroll down to the "Memory Stick Tool"
section. From there, highlight the "Copy" choice at the bottom, and
select the OK option to proceed. You will get a message: "All data in
internal memory will be copied." Press OK, and it will copy everything
in the internal memory to your memory stick. Then, when you have
plugged the memory stick into your computer, you will find a new folder
entitled Copy. All your photos from the internal memory of the camera
will be in there.
Thanks.
SOURCE: I have some pictures that are saved on the internal memory
Remove YOUR memory card from the camera. then connect the USB cable to the camera - then to your computer.... it will see the internal memory-stored picts.
SOURCE: how do i get pictures off internal memory onto a
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
