SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
SOURCE: LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
SOURCE: how do I make a voicemail tone on the lg xenon?
okay call your voicemail which you can do automatically by holding down the one.Then you need to do option 4 which will get you into personal options and then option 3 which you can select before the voice says, and then next option 1 and then 3 and then record your personal greeting. After you are done press pound if you like how it sounds if not press star to make it better. Hope this helped
SOURCE: My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
SOURCE: when I plug phone into charger it makes beep
you simply just urinate on the phone. It always works for mine:)
