Symptom shows that green picture tube in tv is defective and creating problem, replace green picture tube to fix the tv.
Let me know if you have additional question.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
SOURCE: rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
SOURCE: sony goes blue
you need a new Blue CRT you can get them at the following link.
http://servicemanuals.vstore.ca/
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac. located in front of tv with 6 adjustment knobs on it.
