Hi...
From this website you can get the for your remote
http://www.jascoproducts.com/support/universal-remote-codes.asp
follow the steps to set up the remote
Method 1
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
SOURCE: GE JC024 universal remote control
ManualsOnline actually has a new remote code finder - http://universalremote.manualsonline.com
SOURCE: I have lost my manual
Try
0049 0097 0110 0004 0268 0012 0108 0180 for your Sanyo.
You can download a manual from
http://www.jascoproducts.com/support/manual-downloads/index.asp
Let me know if you have any other questions. Thanks.
Please rate this solution. Thanks.
