Question about Sony BDP-S360 DVD Player
It is not playing any dvd's. It says invalid or
It is not playing any dvd's. It says invalid or unknown disc.
    Scholar:
  • 41 Answers
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
1. Ensure the Easy Setup procedure has been completed on the BD player.
NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
2. Ensure the inserted disc is compatible with the BD player.
NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step.
NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
4. Use a soft cloth to clean the disc.
5. Examine the disc for any cracks or scratches that might be interfering with playback.
6. Attempt to play another disc.
NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
7. Remove the disc from the BD player.
8. Turn off the BD player.
9. Unplug the power cord of the BD player from the electrical outlet.
10. Let the player remain without power for 1 minute.
11. Plug the power cord back into the electrical outlet.
12. Turn on the BD player.
13. Insert the disc into the BD player.
14. Attempt to play the disc.
If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
Here is the link to download and install the Firmware update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS360
Select the correct Operating System and download the Firmware update.
Then follow the instruction on the same to install the update in the Player.
If the issue is not resolved even after installing the update, then Playe may require service.
Posted on Jul 22, 2010
    New Friend:
  • 4 Answers
Try to insert a cd cleaner.
Posted on Jul 21, 2010
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Posted on Mar 23, 2007
Anonymous
SOURCE: Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Posted on Feb 01, 2008
mscdunn
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
Kirsten5
SOURCE: LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Posted on Jun 05, 2008
walesarumi
Walesarumi
  • 6993 Answers
SOURCE: my dvd player plays cds but wont play dvds says
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Posted on Apr 22, 2010
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
My dvd player plays cds but wont play dvds says disc error or unknown disc
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
Disc unknown
Not all media discs are playable in all machines.Not all formats are supported in all machines.Coppied and Bootleg discs will not play on expensive players.Dirty,figerprints,badly scratched,all will have problems.Use a disc cleaner (liquid,and fine cloth) to remove scratches.Buy a $ 25-35 cheap player they play anything.Good Luck.
Sep 07, 2009 | GoVideo VR5940 DVD Recorder/VCR
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Dvd player gives unknown disc
thats because its region locked..do the following:
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
do let me know if it worked.
Oct 29, 2008 | Philips DVP320 DVD Player
Unknown disc error
Oct 28, 2007 | Philips DVDR630VR DVD Recorder/VCR
Dvd "unknown disc" message coming up
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Sony BDP-S360 DVD Player Logo
3,161 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
