Samsung YP-T10 Digital Media Player Logo
Anonymous Posted on Apr 22, 2008
Bluetooth headphones no longer working
Hi my Samsung Yp-T10 8gb was working fine with the bluetooth headset until last week when it stopped working and asked for my pin to connect the headphones, I entered the pin which is 0000 and now it keeps coming up with connection failed, any help would be great as it was awesome not worrying about the ;eads on the headphones at the gym.
Thanks ASh
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Samsung Master 1,001 Answers
  • Posted on Dec 22, 2016
wwlvictoria
Samsung Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603577
Points
6027
  • Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
  • Easy to use it, Great for listening music,other you can answer mobile phone calls as they come in by pressing the button on the ear piece.The simple user interface on one of the earphones allows you adjust the volume, play/pause, select songs and answer/hang up calls completely effortlessly.
  • High quality,guarantee you enjoy a clear sound in noisy occasion.Powerful rechargeable battery provide 5 hours of Talking/Playing time. Rubber adapters, unique flexible design and custom earbuds ensure you get it perfect fit and remain stable in your ear
Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Green...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
172
Points
0
Hi found the sulution by going through the forum all I had to do was start the transmitterby holding power down for 15sec then the light changed to a red blinking one then the samsung connected straight away thanks
1helpful
3answers
Windows 7 can't find driver for my HT820 headset. using a PC850 usb dongle and have installed the windcomm drivers.
Install Service Pack 1. Up until this was released a couple days ago, I was never able to get my HT820 to work with my Dell XPS with internal Bluetooth. After SP1, it worked.
16helpful
Pair my samsung sbh170 headphones
set your mp3 ready to find your headphones.
1. Turn headset off 2. press and hold the "calling button" ---do not let go--- 3. slide the on/off switch to "on" don't let go of the "calling button" 4. it will flash blue red and purple (twice) then will turn solid blue 5. let go of the button 6. your mp3 should be able to find it now (that puts headset on discovery mode)
if it works for you don't forget to rate me
thx
1helpful
2answers
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
3answers
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
27helpful
2answers
Cant get my Samsung SBH500 to pair with my Samsung MP3 PLAYER,yp-t10
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
HOW TO PAIR A BLUETOOTH HEADSET WITH A SAMSUNG YPP2 MP3 PLAYER
You have to go in to the blue tooth option on the menu of the p2. Then click search. Hit the sync button on the headset. It should find it in less than 20 seconds.
1helpful
3answers
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
2answers
No sound from pc after disconnecting from headset
Open up the Sounds and Audio Devices control panel, hit the 'audio' tab and make sure that the default playback device is not the bluetooth phones, but rather you sound card.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
