Hello i hope u 'll be fine.... thanks for using fixya. NF 79 is actually an internal firmware error. It means
unit has encountered an firmware error internally. To solve it try this If printer is plugged in to a
surge protected extension lead then remove it and plug it directly in
to the wall socket.After it retry. If this fails again, then replacement of formatter of the printer is best option. Best of luck I hope
this solution will helpful 4 u. Best of luck Please
keep thumbs up in do rating THANKS & Keep
using fixya
Here
is the link to HP Official Support site. You can download the User
Manual for HP LASERJET M1522 NF MFP Printer. Go to Section 10-
Fax (Page 69) for complete and step-by-step instruction for setting up
fax.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Use this link to get the drivers you need. This page has a list of operating systems to choose from. Select the operating system and then select the drivers to download:
it just means that the printer can't read a tiny eeprom chip on the cartridge. 10.10.00 refers to the black cartridge, and you should be able to continue just by hitting the ok button. it should go away with the next cartridge.
fax seting for incomig outgoing
make/model - hp laserjet m1522 nf
