It's frozen in the middle of processing mode on the screen and won't connect to the computer
1. Use the supplied USB cable to connect the Walkman to the Computer.
2. Disconnect all other USB devices if you have connected to avoid conflict.
3.Connect the Walkman to the other USB ports on the Computer.
4.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under
Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If
the issue persists, then connect the Walkman to a different Computer to
check whether the issue is with the Computer or the Walkman.
If
the issue persists even with different Computer, then try resetting the
Walkman by pressing the RESET button located at its bottom. You can use
any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
If the issue persists you may try using a different compatible USB cable.
Try to restart both PC and your walkman. I usually have same experience too everytime I continuously doing new tasks for both. Of course, check the compatibility of your PC features to your walkman too.
