SOURCE: All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel. bye
SOURCE: Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
SOURCE: alignment failed notice
Could be one of two things....
1 - you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Change cartridge (color first) before doing anything.
Inkworks
866-381-0541
SOURCE: blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
SOURCE: HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
