Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Anonymous Posted on Jul 23, 2010
Oh boy. Here goes. We have a Bizhub C450 copier
Oh boy. Here goes. We have a Bizhub C450 copier that has jamming problems every 20-30 copies. The copier tech came out and replaced the feed rollers and assembly rollers. Didn't work, but cost us some. I was then told it was the clutch bearings. Bought those and he came out and it didn't work after installtion. Cost us again. Now he called a tech support company who informed him we need to replace the whole right hand side door at $400.00 plus install and service charge. I groaned, and called another tech who specifically works on Konica Minoltas, and he said we don't need to replace the door. He said a good tech should be able to look at everything on the door and determine what the problem is. Whoa! We havn't had the KM tech come out as they charge a trip charge and service call of $275 just to come out! We've already paid so much as it is! After telling the initial rep what the KM rep said about not replacing the door, the initial rep then said he feels it is not the entire right hand side door, but the transfer roller motor! Now what?! Can anyone advise me please? By the time I'm done with the repair of this Bizhub, I'll have at least 6 months of copier experience:o) or ? Thank you so much in advance of anything that may help. I hope to hear from you soon.
Pam
  • Anonymous Jul 23, 2010
    I wish I lived in Kansas! If it's good enough for Dorothy, it's good enough for me:o) I can 't begin to tell you how helpful you are, and this is. Can you tell me how to enter the service mode please and look up the jam history? I've entered codes before to re-set the machine. Lucky me, when the machines were jamming or having minor problems the tech would tell me how to re-set it. I'm sure I can go into service mode and capture the jamming history. I know I can go no where from there, but at least I can feel a bit better knowing I won't have a problem with huge parts like the door:o) You are a Guru, and absolutely terrific! Thank you so very much!
    Pam
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Jul 23, 2010
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544882
Points
4088
Press Utility/Counter
Over at the right side of the display touch "details"
Now press Stop, 0, 0, Stop, 0, 1
This should get you to the service mode screen
Now touch Counters
Now you can touch either upper right corner is Jam
lower right corner is jam history.
For our purposes the Jam tab will be better. You can just list any location that has a number next to it greater than zero. There are 2 screens to look at as there is a 1 and 2 at the left side.
Obviously we are going to want to concentrate on the lines/locations with the biggest numbers. If there is one location for example that has 40 jams on it and the rest are 3 or 4 then that will tell you where the problem location is.
Now another word of caution. We do not know how long it has been since these counters were reset, if they have ever been reset. So once you get all of the locations listed with how many jams there were I would exit the screen to where you first entered the service mode and now touch the reset tab then the jam tab so as to reset the counts. Now as you run the copier we will have a fresh set of jam counts by location in case we need it later.
Good Luck
Testimonial: "The Guru is by far the most intelligent, honest, copier genius I have ever met. He will solve your problem from the start! I can't thank him enough!"
  • Anonymous Jul 24, 2010
    Thanks for the compliment....just here to help.
    Oh and my expert name here is Wheatlandsvc...short for Wheatland Services which you can Google.
    Thanks again and good luck.
Anonymous
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Sep 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
50423
Points
85
If your still having jam problems, one thing to always do to prevent jams is clean the rollers. The black long rubber rollers on the right side door (not the foam one, thats the transfer roller)
Use a soap like Simple Green cut in half and a rag. You dont want the rollers to get get a build up from paper and toner.
You also can print out the jam and service log by Tech Mode under List Output
Konica Minolta Bizhub C452 Copier. Why does my Konica 452 cast a black shadow when printing?
Question edited for full make model name.
Question moved to model category.
Try this
Thread: Bizhub C450 Print Shadow!!!
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Sep 9, 2009 - Working with a Bizhub C450 that has started to print with a shadow on black and white prints. This problem does not show up on color prints.
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
1helpful
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Bizhub c450
On your printer settings on your computer when you select to print there should be a box that says only use black ink. Try that first and if it still prints in green you may have them in the wrong ports.
6helpful
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
2helpful
2answers
Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
I get error code c5354 on my bizhub c450. It doesn't move from there
Lower left rear, is the Ozone fan might be jammed clogged M-18
remove the rear panel looking at the rear panel right side lower also there is filter assigned to this fan
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
I have a Konica Minolta bizhub C450. Can the image unit be reset?
It may, but this mean that next time you put toner on the machine, you will expect less copy quality and printing for each toner bottle.
Copy speed slow ( on bizhub c450 ) and show three angle shape
good luck
Description:
The machine copies very slow and well below the rated output for black and white and color.
Solution:
CAUSE: The machine memory is corrupt.
SOLUTION: Perform a data clear:
1. Browse to the NIC/Log on as Administrator/Select the Scan tab/Import Export and back up the one-touch addresses to the desktop.
2. Enter Tech Rep mode.
3. Select System 1.
4. Select Data Clear and press start. Wait for the machine to cycle OFF/ON and for the POWER OFF MACHINE WITH THE MAIN POWER SWITCH message.
5. Import the one-touch list back to the NIC.
6. Re-install the HDD and power the machine OFF/ON.
7. Reset the Marketing area to U.S. and the target to U.S.
8. Re-install the TCP/IP address and power the machine OFF/ON.
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
