Panasonic Lumix DMC-LZ5 Digital Camera Logo
Posted on Apr 22, 2008
CLEAR PICTURES OFF DISC
HOW DO I CLEAR THE PICTURES ON THE CARD IN THE CAMERA?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
90
Points
Select a picture (pres rev button)
Then press the Del button twice.
The display gives you the option to delete all the pictures or multiple pictures.
Hank
Have Samsung S630 Do not have disc o download pictures in omputer Does not recognize camera
Consider getting a card reader instead. Once the memory card is inserted into the card reader, the card will appear as a disc and you can simply drag-and-drop your pictures like any other file. It will also be faster than going through a USB cable.
Took about 10 pictures today without realizing disc wasn't in camera. How can I get them on disc to print or send emails?
How do you normally download your pictures?
If you do it by connecting your camera to your computer, simply remove your memory card before making the connection. If you do it by putting your memory card into a card reader, first use the "Copy to Card" command in the playback menu to copy the pictures from the camera to the memory card.
3helpful
I have a Canon Rebel xs..that is reading card write protected...how do I clear that...the card is now empty and the pictures are on a disc
Take the memory card out of your camera and look at it. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Cannot tranfere pictures from disc to computer
Disc? Do you mean camera?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
1helpful
Deleting pictures from disc
It varies with different brands and models of camera, but it is almost always simple, something like this: Go to viewing mode, usually by pressing a button with an arrow on it. You can step through the pictures with left and right sides of the button ring. If you want to delete one, press the button with a trash can on it. It will ask if you are sure. You will have to move the highlight to "Yes", and press OK. This will only delete that one. In a few cameras, the list with Cancel and Yes will also have Delete All. That one will delete all the pictures on the card.
Dec 29, 2011 • Cameras
My camera's reading "disc error". I need to retrieve the pictures
Get a card reader and use it to download the pics to a computer. Then, format the card in the camera to get it to work properly again.
I do not have the disc to transfer my pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Camera will not read disc, I have formated disk and have transfered pictures onto disc. Disc is working and can view pictures from disc on my computer. when I put disc in camera I keep get message to...
If you have moved pics from your computer to the card and then inserted the card into your camera, the card is now formatted to the computer, not the camera. You're supposed to format the card in the camera.
Although USB Mode is set to MASS STORAGE, still max out at 28MB
be more clear ...what is the relation you want to do ....from what I understood...you have a vivitar camera...( web or digital shooting pics??)
what about the disc?? is a memory stick you want to use?? or a sd memo inside the cam ...
the problem must be from the camera than ...cause you do not have to set any of the settings you done ...
you just make your pictures and when you want to download into the pc ...just plug it in ...and the pc will recognize the memory card ..as a removable storage device....
or if you have the drivers from camera ...install them and the programs from the disc and the choices will be multiple ..
I know i didnt been clear enough ...and you can also ask me more on yahoo at catalin_yo_vlad
Good luck !
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
