Question about Panasonic Lumix DMC-FZ8 Digital Camera
The flash on my camera will not turn on no matter what I do. The flash button won't bring up a flash menu or anything. Any suggestions?
    New Friend:
  • 13 Answers
Flash is deactivated in motion picture mode, scenery, night scenery, sunset, highsens, starry sky, fireworks or aerial photo in scene mode.
Posted on Aug 25, 2010
6ya staff
SOURCE:
Panasonic DMC-Z28 - the flash button does not call up a flash setting menu and so the flash won't turn on.
Is your Z28 set up to do burst shooting as this will stop the flash working, click on the trash button and turn off the burst shooting. Hope this helps.
Feb 12, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
How do i get the flash to work all the time on my nikon coolpix
Press cursor-up on the multiselector (marked with a lightning bolt) to bring up the flash menu. Select the lightning bolt icon and press OK.
In some scene modes you won't be able to bring up the flash menu. In this case change the shooting mode first.
Jan 30, 2012 | Nikon COOLPIX L20 Digital Camera
Samsung TL110 Digital Camera Has A White Screen I probably only ever dropped it once or twice and that was MONTHS ago. NOW there is a white screen on the camera and no matter what I tried, it will not...
Since you are able to see the menu items and stuff this is not an LCD screen problem , as you have already figured out the hardway. I have seen this problem appear either due to a faulty battery or a malfunctioning CCD-image sensor.
In both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Sep 26, 2011 | Samsung TL110 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
I have a monitor, i actualy don't know the name of the model, but i have the model number.. ive had this problem for around 3months and can't find a way to fix it. basically, it's that old story about...
The input (either VGA/HDMI/DVI) maybe be defective. Generally with these sorts of problems, either something goes defective in the port, or the cable. You said you tried different cables, so, it is probably the connection to the port inside of the monitor. Hope this helps!
Feb 28, 2011 | RCA IISonic IIMJ9 19 inch LCD Monitor
How do I turn the flash off of a Samsung S860 digital camera
Press cursor-left (marked with a lightning bolt) to bring up the flash menu. Select the lightning bolt in a circle with a slash through it to turn off the flash. Full details are in the "Flash/Left button" section beginning on page 28 of this manual.
Jan 24, 2011 | Samsung S860 Digital Camera
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
Hi there, my Nikon D40x flash suddenly stopped working (popping up but not flashing) after I was fooling around with the manual settings, now no matter what I do the "no flash" icon appears beside the...
Try turning camera on,
Then press both Green buttons for a count of 10. This should restore factory reset.
Some models also have a reset button under a connector flap, or go into your menu. Under Custom Setting Menu, choose Menu Reset.
One of these methods should work.
Sep 22, 2009 | Nikon D40x Digital Camera
Nikon coolpix 774 menu buttons don't work
Try resetting the camera back to the factory default setting.
Remove the battery, leave it for 1/2 + hour, insert the battery and configure date time etc.
If it doesn't work then you have faulty camera.
Dec 03, 2008 | Nikon Coolpix 775 Digital Camera
Flash
Top of the camera, lightning bolt like button. When you press it while the camera is on, it will bring up a menu, there should be an option in there to shut it off.
May 28, 2008 | HP Photosmart M527 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
