Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hot Point Dishwasher is leaking water. It was
My Hot Point Dishwasher is leaking water. It was on the wash cycle. Water every where. Can not see where it is coming from. The model # is HDA3400G02BB
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Jul 23, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232523
Points
12714
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
1helpful
Dishwasher shuts off mid cycle
Hi Ray.
i found this out.
The reason for the dishwasher to stop mid cycle is that the thermal fuse is shorting out because it is either fouled, dirty, broken, or loosely connected. If your dishwasher is older, the thermal fuse is used as a safety switch to stop the motor and circuit board when the dishwasher gets too hot.
or go to this link might help you out.
https://fixappliances.ca/dishwasher-repair/why-your-dishwasher-starts-and-stops-during-wash-cycle-and-how-to-fix-it/#:~:text=The%20reason%20for%20the%20dishwasher,the%20dishwasher%20gets%20too%20hot.
1helpful
Dishwasher fill timer not long enough-GE Profile dishwasher
No. There is no way to change that. A dishwasher will accommodate low water pressure but only to a point. You can add hot water manually but that’s work and a over flow could happen. I assume you have hard water because of the well. This could be your problem. Overtime calcium deposits can build up inside the water valve or at the point of entry. Especially in a older dishwasher. I’ve seen it happen many times. The water flow is restricted causing a low water fill. You can clean it out yourself if your handy. Good luck
Hi, I have a Maytag Mdb8959sas dishwasher that was leaking during a normal wash cycle. I pulled the dishwasher out from under the counter and saw that it appears to be leaking directly below the point...
I will assume that you have cleaned gasket around door and at washer. Quite often a build up of scale at lower gasket surfaces is all that is causing leak.
Feb 19, 2014 • Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 • Dishwashers
    2answers
    Asko dishwasher d3530. The water in the dishwasher is not hot.
    Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
    Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
    Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
    I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
    Good luck. Hope this helps.
    5helpful
    3answers
    "HO" flashes on display during washing.
    HO, indicates that the dishwasher is using Hot Water. It is completely normal.
    Hot water for dishwasher
    Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
    Oct 06, 2008 • Dishwashers
    Dish washer
    If your dishwasher's cycle times are too long, check these:
    Water pre-heating
    Cycle not completing
    Water pre-heating
    Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
    cool, the heater may take up to half an hour to heat the water.
    To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
    Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
    of the hot water to the entire house at the hot water heater.
    Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
    120 degrees Fahrenheit.
    Top Hotpoint Dishwashers Experts
    Mike Cairns
    Mike Cairns
    Paul Carew
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
