My T.V when i press the power button it comes on but there is no video and theres audio . I recently open it to check the sensor because it is not working with the remote , but it works manualy. Something happen or i move that cause it to loose the video could you help me to solve the problem. Thank you very much
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into. Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
HI MARTYN,
Toshiba allow cheapo makes to use their brand name sometimes.
So if the player is not a genuine Toshiba then there is likely to be a remote hack on the net some where.
If it is a genuine Toshiba then there wont be a remote hack and you will need somebody like DVD Chips to send you a £20 remote that will hack it.
However - many Toshiba machines will not play NTSC discs at all when first set up.
Check out the Video setup menu and you will see a PAL/NTSC/AUTO option.
Tosh's I've seen are preset to PAL but unlike other players the Tosh will spit out any NTSC discs you try to play- set it to AUTO
Check that setting first just in case that is the only thing stopping it
Here's a Tosh hack to try
1. Press the Open button on your remote control to open the drive tray 2. Press the 2 button on your remote control 3. Press the 4 button on your remote control 4. Press the 0 button on your remote control 5. Press the 3 button on your remote control 6. Press the 9 button on your remote control 7. Press the 6 button on your remote control 8. Press the 0 button on your remote control 9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback 10. Press the Open button on your remote control to close the drive tray 11. Power off the DVD player 12. Power on the DVD player
If the hack does work make sure the PAL/NTSC setting is on AUTO because R1 disc might still not play
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
This usually means a safety sensor issue. Try holding down the wall button. If the door moves downward as you hold it then it is the sensors. If it does not it is probably a capacitor. YOu can get replacement parts at searspartsdirect.com. Thanks BB
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio. If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
i am no whizz, but i think, just THINK maybe you should get some friend or relative to check the wiring to the fan and the power button, maybe when cleaning the fan, the wires were losen, as the button is millimeters away from the fan.
i hope it might help, if not i already said, i'm no whizz
