SOURCE: Toshiba 37X3030D LCD TV
no, the tv has a setting that auto changes the screen ratio. you can turn the auto screen ratio off in the settings section. Once you have turned it off put ratio to 16:9 and it will solve the problem.
SOURCE: Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
SOURCE: I have a Toshiba 50hp66 that the power light
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
SOURCE: have just purchased new toshiba
When installing the tv channels, the system must search for analogue and digital channels. It sounds as though it didn't complete the installation procedure.
Let it try again.
Hope that helps.
