Question about Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
Stihl MS250C Chainsaw works great won't turn off!
Stihl MS250C Chainsaw works great but won't turn off. I took the cover off and there is a black wire with a connector but it does not go to anything. Have I lost a part? I need a diagram of this model to see what is supposed to be there. Somebody please help! Thanks for looking!
  • Akenco Jul 23, 2010
    I must be stupid, lol, cause I am not understanding. I wish I could post a picture on here of what it looks like. I completely understand what you said and I think I found the place that it goes but it is just plastic so I am not sure how it would ground. Trust me, I am not the brightest crayon in the box. lol There is like a channel in the plastic part of the inside of the switch that the connector goes into (not sure if that is where it is supposed to go) but still won't turn off. There is a flat wire that comes out and makes a v under the switch but it does not connect to anything either. This is one of those times I wish I could find a parts diagram for this thing. Thank you so much for your help. Sorry I am so dense.
  • Herman Teachout
    Herman Teachout May 21, 2017
    If this black wire has a connector on the end that looks like a metal extension to the wire... It hooks into a slot in the control lever shaft. ie, the control lever is the single lever that moves from off to on to high idle to choke. The right side of this lever shaft fits into a little socket. (take off the air filter so you can see it better) and the left side fits down into a clip in the white plastic. The black wire fits into a little groove in the control lever shaft. Note: it goes in somewhat backwards than what would be intuitive. in other words, it goes in from left to right so the insulated portion of the wire goes in first and the metal connector portion goes in last. When it is properly installed, the flat spring that rests against the control lever cam will touch the black wire's terminal end and the engine will quit when the lever is moved to the off position. The flat spring should be above the control lever cam, not below.
  • 760 Answers
That wire should go to the kill switch. IT just grounds out the magento. See the on off switch, and put it back on there.
Posted on Jul 23, 2010
Testimonial: "Very quick thorough reply and very on top of his information!"
  • Stihl Master
  • 2,015 Answers
If after a period this can allways happen by every kind of powertool where the ignition coil is mounted to ground to stop the engine, if its disconected to the ignition module but at the moment much people do not know how to get it off at that moment, also power generators or other fuel machines " Use the choke " it will stop in a little surpluss of fuel and remember if that happend to not use the primerbulb if there is one by next start
Stihl MS250C Chainsaw works great won't turn off! - stihl-ms250c-chainsaw-works-great-turn-1gceyanr1zc5z3ghoaajtjkq-3-0.jpg
Posted on Apr 07, 2016
    New Friend:
    Problem Solver:
  • 5 Answers
Yip jus a ground wire or earth wire what ever you know it as jus kills engine
Posted on Apr 25, 2013
6ya staff
SOURCE:
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
Need replacement part for MS 250 C ignition coil
There was two ignition coils used on the MS250C series. Which do you have?
MS 250 C-B, MS 250 C-B Z, MS 250 C-BE, MS 250 C-BE Z ?
Also these parts are only available through Stihl dealers.
Jul 30, 2015 | Stihl Garden
How do I change the fuel filter on a o25 stihl chainsaw?
Make a hook out of wire about 7inches long open gas tank it should be empty, look in there should be a little black hose with fuel filter on it hook hose work it out to replace filter
Sep 21, 2014 | Stihl Garden
I have a Stihl 039 chainsaw that kicks back when starting.
check for a sheared or bent flywheel key...
Dec 03, 2013 | Stihl Garden
Having trouble shutting off Stihl chainsaw
the kill switch wire might have broke between the coil and the switch
May 19, 2012 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
I need help in replacing a gas line on a Stihl chainsaw model ms250c. The line is cracked and leaking bad.
Best way i can help is to fix it for u. But if u want to try here goes. Pull off air cleaner housing, Fuel line runs from left of carb to under carb, remove. install new line. Looks easy, sounds easy, very tight fit.
Aug 24, 2011 | Stihl Garden
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw Logo
6,195 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
