E20 is problems with draining. check pump chamber at plinth area of washer. first drain water out of drain tube (at side of pump access area). can be blocked at connection with waste if under sink connection.if not these pump may be faulty.
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on.
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Hi just read your posting.Now what I need to know is the model number of your machine which can be located on the back on a sticker.Also when it stops in the rinse cycle does an error code appear in you LCD screen if you have that model or do a series of lights come on and in both models it beeps.Now if you have the model where the lights come on they will be in a row of 8.Starting from the left to right what lights have turned on when it stops in the rinse cycle Is it the 2nd and 5th or the 3rd and 8th --etc-?Please reply with this additional information and I can help you rectify this fault for you.
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
