Select the timer mode (left arrow on the 4-curser-button). There are 3 settings in the order of 10sec timer; 2sec timer and timer off. Select either the 10 second timer (if you want to be in the picture) or the 2 second timer (more appropriate for long exposures when camera is on a tripod or similar to avoid camera shake when pressing the shutter button), then press the shutter button fully. The subject will then be automatically focused just before the picture is taken. There's a little light on the front of the camera (top right hand corner when you look at the camera) which should blink when self timer is activated. Pressing the menu button while timer is activated will cancel self timer mode.
In low light conditions this light may turn on brightly to double up as an AF assist light.
Hope that helps
You aren't supposed to leave the timer cocked for long
periods, probably because it could wear out the timer spring (similar to the
reason you aren't supposed to store the camera for long priods with the shutter
cocked).
I thought that you set the timer by rotating the timer lever
90 degrees or more counter clockwise (when looking at the front of the camera).
The further you rotate the timer, the longer it will run. Moving the timer
lever exposes the start lever underneath the timer. Pulling the timer lever
counter clockwise (it starts out pointed straight up) will start the timer, and
putting the start lever back in it's original position will stop the timer.
Once the timer is stopped it is possible to take a
picture by releasing the shutter normally, the timer can be restarted, or the
timer can be reset for a longer time. After the timer is stopped it should be
restarted and allowed to count down to zero before the camera is stored. I'm
almost certain that the timer can only fire the camera if the shutter is
already cocked, so it is safe to release the timer and let it run down any time
that the camera is not cocked.
Good luck and do rate the solution if helped
