1) lube the deck belt very well 2) lube the rollers bearing too 3) lube the bearing from the main motor,+test the pulley+belt for replacement need lubrication go to the repair shop. 4) otherwise you must call some tech for repair. see the video. God bless you
Either the walk belt is loose or the front roller pully has spun. In order to determine which one, you need to remove the moter cover and watch the drive belt and front roller while you walk, try to stop the belt and see which one stops. If the walk belt stops and the front drive roller keeps turning, then you need to put a couple of turns on the rear allen bolts. If the roller stops when the walk belt stops, see if the drive belt(small one going to the motor) stops as well. If the drive belt turns fine,but the walk belt and the front roller stop, you need to replace the front roller, because the plastic pully that is connected to the roller, is pressed on and cannot be tightened.
Discription: WALKING BELT W/FASTENERS, Part # 193575, Model # PCTL49820, Price $48.83 In humble opinion you should replace the part, it sounds like an accident waiting to happen Call Icon Fitness @ 800-999-3756 and give them the info above.
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
PROBLEM: The walking belt is off-center or slips when walked on
SOLUTION: a. If the walking belt has shifted to the left, first remove
Using the hex key, turn the left idler roller bolt clockwise
walking belt. If the walking belt has shifted to the
right, turn the left idler roller bolt counterclockwise 1/2
of a turn. Then, plug in the power cord, insert the key,
To adjust the belt:Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction.More Belt Tension:Turn both adjustment bolts equally in a clockwise direction.Center Adjustment (moves belt center to the left):Turn left-side adjustment bolt counter-clockwise.Center Adjustment (moves belt center to the right):Turn the left-side adjustment bolt clockwise. An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt. You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
