Question about Nokia 6300 Cellular Phone
Nokia 6680, Phone start-up failed. Contact the retailer.
Nokia 6680, phone doesn't open, when press power on button display starts with NOKIA and then after some seconds it cannot open up. display shows - "Phone start-up failed. Contact the retailer."
  • Anonymous Mar 24, 2014
    i only able to open my facebook on computer
    New Friend:
Nokia 6300 phone start-up failed
Posted on Jul 24, 2010
    New Friend:
Me softwear update kr rha tha me ne data cabel nikal di is leye mera phone start nhi ho rha or na he softwear ho rha he
Posted on Apr 21, 2012
6ya staff
SOURCE:
Nokia 6680 phone start-up failed. contact retailer
flash atf box write rpl decrypt 309 PM rewrite full format repair simlock and if necesary reflash
Jul 05, 2012 | Nokia 6680 Handheld
My nokia 6680 can't start up is telling me to contact a retailer
Press the " *, Green, 3 " it boots the phone like normal.
You can make phone call and everything.
(it actually BYPASS "contact retailer" screen)
But when it auto shuts down or low in battery.
when you switch it on again.
It comes back to the screen
"Phone start-up failed"
"please contact retailer"
So the above mentioned is the temporary solution. For permanent one please contact customer service center.
Dont forget to rate me. Thank you.
Feb 09, 2011 | Nokia 6680 Cellular Phone
Phone startup failed Contact the retailer.Nokia N91
Problem: Nokia 7610 startup failed contact the retailer
Solve: You Need to format your mobile and this is the way
First of all Turn Off Your Mobile Phone
[ format = power + press & hold call + * + 3 ]
Jul 19, 2009 | Nokia N91 Cellular Phone
I need solution for start up failed contact retailer
type code *#7780# on the display screen message appear restart your phone original settings then ask for code default code is 12345 .your phone restarted and all data on your phone erase
second method first of ur cell phone then press on button answer key or red button then 3 then * press these buttons at once for few seconds and then leave it and ur phone start formatting
Feb 23, 2009 | Nokia 3230
Mobile not open "phone start-up failed. contact the retailer"
press and hold SEND key+* key+2 key when you switch on the phone
Jan 18, 2009 | Nokia 6630 Handheld
Please help me,6680
try reformating it..
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
it will refresh your phone, reformat it and reinstall all ur apllication
Sep 22, 2008 | Nokia 6680 Cellular Phone
My nokia 6680
Your phone can be repaired by formatting (soft/hard)
For hard formatting as your phone is unable to start,
Keep pressing
'Green', ' * ', and ' 3 ' keys and start the phone.
Keep all the buttons pressed till the phone says "Formatting"
The phone formats, starts, and all the data is lost.
But the phone is all OK as before.
Please Rate.
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
Jan 20, 2008 | Nokia 6670 Handheld
My phone hangs and failed to start
Have you tried to format your 6600 ?
Turn of the phone, Press and hold " 3 " - " * " and " green ", then turn the phone back on while these buttons are pressed down.
Its kinda tricky, but can be done.
If this doesn't work, you have to bring your phone to your local Nokia Service-Center and have them repair it.
Oct 11, 2007 | Nokia 6600
Nokia 6300 Cellular Phone Logo
1,425 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
