Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature. If it's bad, replace it BUT you have to CLEAR to error code. 1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard. 2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it. 3. Press SENSOR DRY and TIME keys for 3 seconds to clear it. 4. Power OFF to exit Service Mode 5. Power ON
Maytag Dryer and FE code means power source "Frequency Error". Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts Hope this helps (remember to rate and comment this answer).
5. Power ON
Hope this helps
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used. If you find a place that sells the heating element please post!
