To burn videos to playable DVD , you need a professional DVD burning program to help you do the job. You can try Leawo DVD Creator. It can easily burn all kinds of videos to a DVD disc. The advanced burning technology within the software can allow you to burn your video at high speed and preserve the original quality at the same time.
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can have problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that everyone were under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. Also, you could be using the wrong type of disc. Try DVD+R.
HI THERE,
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
