The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: Canon Powershot A430 horizontal lines problem
have opened my camera. (it was useless anyway, right?) GUess what I found: in the lens-assembly there is a ribbon cable that controls the two solenoids, one of the shutter, one of the diafragm (or what it's called). This one is broken, the electric circuits are discontinued and so there is no control. It seems to be a design error since it broke exactly where the ribbon bends at 180 degrees almost with no place for a loop most of the focussing time. Can anyone find out where to find a NEW replacement ribbon cable?
SOURCE: Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
SOURCE: how do i turn on the date stamp on my Canon Powershot SD750
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
SOURCE: I have a powershot A480 canon camera and it date
If you press the "Function Select" button then press the outer ring UP or DOWN to select the icon that looks like a clock on the left and panel. Then press the outer ring LEFT or RIGHT until the L is selected and appears in the panel on the LHS. That will remove the date stamps from the photos.
Cheers, Richard
PS Great choice of camera by the way.
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
