Sharp AR-5316 Advanced Digital Imager Copier Logo
A
Anonymous Posted on Jul 06, 2010
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1667
Points
6
I have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
amir hamza
Level 2:
  • Sharp Expert 318 Answers
  • Posted on Jul 25, 2010
amir hamza
Sharp Expert
Level 2:
Answers
318
Questions
Helped
188809
Points
694
Heat roller low temperature
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1667
Points
  • rayhan rasel Feb 15, 2014
    quick press # interrupt c interrupt then 14 trart
  • Izuma uche
    Izuma uche Feb 17, 2020
    i have Sharp AR-5316E and it showing L4 what will i do
My sharp ar-5320 copier has an error code blinking it flashes h and 4.
The H4 stands for a problem in the heater circuit for the fusing unit, It could be a thermo fuse, thermostat, thermistor, bad heat lamp or worn fuser rollers. The H4 will not reset until either of these components is repaired or replaced. Hope this helps.
65helpful
6answers
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
3helpful
2answers
Sharp ar-5316 errors
heat roller low temperature direction
3helpful
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
12helpful
6answers
1helpful
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
9helpful
2answers
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
20helpful
4answers
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
17helpful
5answers
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
