Miele Novotronic W1918A Front Load Washer Logo
Posted on Jul 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leak My Novotronic W1918 Miele washer has a bit of a leak. Water runs out from underneath. Do I need to exchange seals?
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Jul 25, 2010
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620799
Points
5972
First you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Water leak on spin cycle no warning lights on
If there's water underneath the machine, check drainage pump. Most likely gasket or simmering. If necessary replace pump (about $45,00).
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Novotronic washer w1918 jumps violently when transitioning from main wash to rinse 1-2 with 21 minutes to go to end of wash cycle
If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
1helpful
2answers
I cleaned out the fluff filter on my Miele W1918 and now the water is draining out the bottom. There is a small drain hose to the left of the filter that the water is flowing out of . Any ideas
hi,
the fluff filter just needs hand tightening up a bit more to stop the leak. if not there could be a bit of fluff trapped between the seals. Remove it again and have another look. Make sure also you don't cross thread the fluff flter which makes it feel like it is screwed in properly when it isn't
Fuse Box
there will be a glass fuse on the power board of the washer it might have cover over it good luck
shaun
1helpful
Miele novotronic w1918 wiring schematics
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
Sir Galahad
1helpful
Miele Novotronic Premier Plus - no water into the machine
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
7helpful
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
