JVC GR-D720 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Jul 13, 2010
I put a new 4gb sandisk hc memory card into my jvc gr d270u video cam and i get card error message with or without the card unlocked.i can not go to the format menu with the card in place.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 25, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955285
Points
33084
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error.
Try 1GB or 2GB memory card in camcorder.
Thanks.
5helpful
Hi,can you help me? what is the correct size,type,make , memory card for a jvc gr-d72u camcorder.
The GR-D72U does not support SDHC cards. You need to use SD cards 2GB and smaller. You can use any brand, though I'd stick with major brands such as Lexar, PNY, and Sandisk.
What kind of memory card do i buy for my jvc gr-d270u
The GR-D270U uses SD cards. They should be available at just about any department, electronics, or office-supply store.
Make sure you get an SD card, not an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
4helpful
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
2answers
I need to buy a memory card for my JVC GR-D270U camcorder. Can you tell me if that model supports SDHC cards?
your camcorder support : Mini DV
you can go for it......
dont forget to rate if that helps...
Need to Import videos from the JVC GR-D270U to my PC
search jvc online or just do a yahoo search,,should find the driver and the program,,you need
Camcorder Communication Error from Battery to Camera
Not 100% sure but when my gz-hd3u had the same problem I cleaned as well as pushed in all the battery connect pins on the camera. one of the middle pins detects if the battery is installed.
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
JVC GR-D270U
You may not need any driver.
Just get a 4 pin firewire cable and connect to PC.
then,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
