Our Loewe Articos 55" TV displays a picture for about a minute and then goes black. The green light does stay on. This behavior is reproducible so I do not think the bulb is bad. The vents are clear and the fan nearest the bulb works. Any thoughts as to what might be the problem? Many thanks in advance. Paul
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
Your problem besides color wheel is the Ballast Board this Board is what turns on Lamp and be sure to CK cooling Fans if fan that cools Lamp is defective Lamp will not light,nor will set turn on!Call Encompass Parts or visit their website they should have listing for parts to your TV 1-800-638-3328 and heres another company you can Call UED 1-800-648-6657 If you need to know anything else let me know.
God Bless and have a Wonderfull Day.
If you have sound and Lamp is not turning on your ballast Board is Bad Call Encompass Parts 1-800-638-3328 or UED 1-800-648-6657 and Both companys have websites visit them online .
God Bless and have a wonderfull Day.
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
95% of the time this is caused by the lamp. Inspect the lamp again 9 times out of 10 the element will be shattered sometimes the force of the fail can cause the glass to shatter, the force can also cause futher damage but this is unlikely. Have the lamp replaced check the hours lamp should last around 3,000 more if you switch off with the remote never the side button. Reset lamp counter to zero.
The main problem for this is that your lamp needs replaced. It is an Osram lamp but many manufacturers had these made to slight difference in specs to ensure only they could cash in on the spares.
