I have used the red and white audio lead supplied with the surround sound to connect to the red and white connectors on the back of the tv and i still carnt get sound from the external speakers. I run my pc through the surround sound and the speakers were ok. Then i used a lead going from the headphones socket on the tv to input on the surround and this worked but was poor quality and the rear speakers did not work. Please help
SOURCE: Satellite A75-S206 : Audio Problems !
You need to download and reinstall sound card drivers for your laptop.
Here is sound driver download page from Toshiba.
Here is general drivers download page for your model
If the links above do not work, start from here, select your model, then chose download and select the appropriate driver.
Regards
SOURCE: headphone socket on my laptop is not working
hey man just try to see if any thing is in there it can block your electrial current if there is make sure you turn your laptop off before using twezers to pull it out other wise it could fry your motherboard
SOURCE: Replace laptop headphone jack (Toshiba Satellite A55-S326)
It on board so its going to take some really good solder work and a new jack from Radioshack. or the other solution is you can buy a sound card from any best buy, computer store or even online for cheaper then you can to fix that professionally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
