Question about Frigidaire GLTF2940ES Front Load Washer
I have all the mold problems related above. I purchased a Frigidaire Model #LTF2940FE0 front load washer on 8-18-07. I can no longer use the machine because the smell is so bad, it leaves my laundry smelling awful. I have tried all the solutions posted above including, Affresh, bleach, etc and none have worked. I will never purchase another Frigidaire model of anything. There should have been a recall. Wish I had known before I purchased this model. I will not buy another front load washer.
  • rregina418
    rregina418 Jan 05, 2013
    nothing gets rid of the mold. NOTHING. BUY a new machine and never pruchase there **** ever
    New Friend:
  • 12 Answers
DOOR MUST BE LEFT OPEN AFTER WASH TO LET RUBBER DRY OR IT WILL MOLD.
Posted on Jul 26, 2010
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
I have a frigidaire gleh1642fs stacked washer/dryer and the washer won't drain.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Frigidaire GLEH1642F Front Load Stacked...
My frigidaire front load washer smells like mildewed clothes; I have wiped down the inside and rubber seals...any ideas???
Here is a tip that I wrote about front load washers and the smells that seem to go along with them....
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Aug 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
MOLD
Hello Friend, Sounds to me like you have a problem with the quality of your water supply going into your washer. Water quality could be a possibility. If the water contains alot of micro-organisms this could be the problem. When you are not using your front load washer the door remains closed trapping in moisture causing mold and mildew to grow. If you just repeat the cleaning process once again with bleach you should'nt have this problem anymore if you leave the washer door partially open when not in use. Happy to help, Tim.
Jun 25, 2009 | Frigidaire GLTF2940ES Front Load Washer
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Rubber Gasket
In the future, leave the door open to dry the washer out between uses
Oct 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
506 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
