SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
SOURCE: Philips 42PF9630A/37
I have the same problem, except with a Philips 50 inch model 50PF9631D/37, except mine sometimes does 6 long flashes and 3 short. Here is what I found, after MUCH online and other research:
It is probably the Power Supply board. One other indicator that it is the power supply board is that if you unplug it for a minute or so, and then plug it back in, it might start up and stay running until you shut it off again (that is what mine would do). Mine eventually would not come back on after repeated unplugging. I have learned that the reason for this is leaking capacitors on the Power Supply Board. If they are really bad (like mine eventually were), the TV will not come on at all. The reason it will stay running once it is going is that there is a separate set of circuitry for the TV once it is going.
I UNPLUGGED my tv and waited 1 hour (for capacitors to hopefully discharge), and then opened up the back of the TV (all you need is a "Torx" (also known as star-head screwdriver, with 2 different sized bits (buy multiple bits if necessary, they are cheap and I don't remember the sizes).
PLEASE NOTE: Even unplugged, TV's have capacitors which store large amounts of electricity which can discharge quickly and kill you. Be very careful. One website suggested wearing special, high-voltage rubber gloves.
The Power supply board is the big computer-looking board in the center. I stared at mine for 15 minutes and was able to notice 2 capacitors with slightly bulged tops. I have learned that this is a common problem with these boards. All you need to do to remove the board (at least with mine) is to carefully (there is a little clippy thingy on the bigger ones) unplug the wires connected to it, and unscrew the screws holding it in with a phillips-head screwdriver.
I was able to find a replacement board at various places on the internet, but the best was BestBuyParts. I found they had 1 Original Board for mine for $300, an updated replacement for $300, and a refurbished replacement for $205. I ordered the refurbished one and will let you know my success when I get it. Interestingly, the original board was made by Samsung!
Interesting side note: I tried to simply replace the $1.00 capacitors on the board to save money, but they are REALLY hard to find. I finally found that the original capacitors, made by Samwha, are no longer sold as 105 degree celcius capacitors, but are now listed as 85 degree capacitors, and their 105 degree replacement is now back-ordered. I have also ordered approximate substitutions, to see if I can save the old board. Bottom line: It looks like Philips bought the board from Samsung, who got some bad capacitors from Samwha, and we all pay the price.
Finally, check to see if there is a recall. 12,000 Philips TV's with Ambilight have bad capacitors which are sparking and have been recalled. I doubt it is related, but I bet I know who manufactured those bad capacitors.
SOURCE: My Philips 42PF9630A/32 screen is black. The
X or Y sustain boards need servicing or replacement............
SOURCE: Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
