Question about Maytag Neptune MAH6500A Front Load Washer
My neptune washer smells like rubber burning when i wash clothes
  • 4,323 Answers
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Posted on Jul 26, 2010
5 Suggested Answers
6ya staff
SOURCE:
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: cloths dosnt ring out any more
Most likely needs a new drive belt.
Posted on Jul 16, 2009
John Morganti
  • 864 Answers
SOURCE: after start washing the clothes a burned rubber
Drive belt is failing and should be replaced. check by looking underneath the washer
Posted on Jul 18, 2009
Anonymous
  • 491 Answers
SOURCE: burning smell from washer
YOUR DRIVE BELT MAYBE WORN AND NEED REPLACEMENT.
Posted on Oct 26, 2009
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Nov 07, 2010 | EuroTech Washing Machines
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Burning smell from washer
Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer has water in the tub after it
You'll need to clean the strainer. It is located between the drum and the pump. and is connected to the drum with a rubber hose.
Best regards, --W/D--
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine spins slowly and smells of burning rubber
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
625 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
