No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
http://www.managemylife.com/mmh/owner_manuals/134/KENMORE-Upright-Freezer-L0307021?brand_name_search=253.23424102+
Good Luck and please rate 4 thumbs up for the free answer.
Look at the shelves, frost free freezers do not have the coils built into them, manual defrost does
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first. 1. Is there a thick frost buildup on the back panel at the bottom half of the freezer? 2. Do you hear the fan running inside the freezer? Let me know what you find.
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
