Hello, I´m from Honduras, I have an Akai CTF2730 TV, and suddenly it stops working, I get it to an expert, and he said the fly back need to be change, thast the part No. BSC70V/UL of the tv, I bougth that TV here in Honduras, but I can´t find that part anywere, even in the store I bougth the TV (PriceSmart Tegucigalpa), so my question is if you have that part of the TV, and how much does it cost. I hope a soon aswer.
Hola Nancypalma11,
Estas partes son un poco dificiles de encontrar hoy en dia debido a que ya no las fabrican.
Revisa el enlace de ebay.com y ponte en contacto con ellos para ver si te pueden mandar esa parte a Honduras. BSC70V UL BSC 70VL bsc70v ul bsc 70v ul Flyback Transformer 6064 eBay
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
SOURCE: Akai PT5598 rear projector TV
usally when this occurs your looking at high voltage problem. flyback, horizontal, crt issues, do you hear any high voltage static or cracling when you turn it on or off
SOURCE: Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
SOURCE: lost remote for akai tv/vcr/dvd set
my, need code for programation my combo in remote control rca
