I have an Behringer Xenyx 1222FX that won't power on but when switching on the phantom power light does illuminate. Checked all fuses and those are fine, I'm assuming something is wrong with the transformer but even after testing with a meter I can't get accurate results. Since I do not know which wires from the transformer supply what voltages etc. I can't determine if what I get on the meter is correct. In addition if it is the transformer I cannot seem to locate a replacement.
Since the phantom power is working, it's unlikely to be hte problem at the transformer. You have to locate the ground wire of the mixer (ususally the lower end of the faders, or the ground from one of the audio connectors). Using your voltmeter you must find one point providing +15Volts and another one providing -15Volts at each of the input stages. I think that the problem is that one (or both) of these voltages are absent. Mention that the +15 and the -15 volts are between the ground and the apropriate pin at the input stages. In case you will not locate the +/-15Volts, or they are 0Volts, post me back for further directions.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Hi, i have the same problem however in my case the dsp db meter is pinned all the time, I have measured the voltage at the power supply and found 30v , 60v and plus/minus 15v. I also found 15v plus/minus at the ground input pin....is the dsp shot? My power light does not come on and there is only a dissorted signal thru any output. Thanks
Can you help me to fix my 1222 henyx audio mixer? No power.
I am filipino.
You can personally message me at my fb acct. Francis Amar.
If you are willing to help me, I really appreciated it!.
