Samsung LN-S4041D 40 in. LCD HDTV Logo
Posted on Sep 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY SAMSUNG LNS4051 LCD TV WIN'T TURN ON (CLICKS AND 4 RED BLINKS)I HAVE READ ALL THE POSTS ON THIS AND REPLACED THE CAPS ON THE IP BOARD.STILL SAME PROBLEM.JUST BOUGHT A BRAND NEW IP BOARD FROM THE PARTS STORE FOR 175 DOLLARS AND STILL WON'T TURN ON .I READ A POST SOMEWHERE THAT YOU HAVE TO SHORT THE EPROM SOME TIMES .DOES ANYONE HAVE ANY KNOWLEDGE ABOUT THIS ?
billconfused
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 211 Answers
  • Posted on Sep 23, 2017
billconfused
Expert
Level 2:
Champion:
Cheetah:
Answers
211
Questions
Helped
59493
Points
377
It's the power board. eBay has them.
3 Related Answers
Anonymous
  • 335 Answers
  • Posted on Jan 26, 2009
SOURCE: Power wont come on... red light blinks... hear clicks but no pix
There are many reasons as to why the tv can default to service mode (blink codes) and may have nothing to do with the power supply board. Flat panel tv technology incorporate intuitive interrupt circuits designed to prevent catastrophic failure regardless of the boards functionality.
Some root causes to this condition may be:
1 Bad inverter board (step-up hi-voltage CCFL)
2 faulty regulator control board (data timing)
3 faulty interface processing board(s) (signal switching)
4 faulty power supply board (main voltage)
5 Bad LCD driver circuit, or faulty LCD panel its self.
6 faulty scan circuits.
__________________________________
To diagnose and solve these particular circuit scenarios require a professional service technician. Any of the problems above would take around 35 minutes and 100 bucks to repair at a service center.
But if you insist on fixing it yourself I can try to help you determine which board is possibly defective. I do have schematics for this chassis. If you have a multi-meter and 5mhz oscilloscope we can get started. These are the 2 instruments needed to check for critical waveforms and voltages according to the schematic data. It could be any circuit in the tv causing this condition.
The components on the circuit boards that could be defective are as follows:
Diodes
Transistors
Inductors
Resistors
Transformers
Crystal oscillators
Filters
Relays
Transducers
Capacitors
IC chip arrays
__________________________________________
Modular causes to this condition may be:
poor resistance too ground
high current too ground
over voltage
under voltage
over current
under current
shorted switch actuation
___________________________________________
Software related blink intervals:
Parental locks
Sleep mode
Hidden key commands (test mode servicing)
"though if in this blink category the tv should come on requiring password. So this is unlikely....
Chi Chu
  • 8457 Answers
  • Posted on Mar 05, 2010
SOURCE: I replaced the 4 capcitors on the panel and the TV
Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Put the old IP board back.Tries it again should work,if u didn't not burn anything in the Tuner signal board. Keep me in touch how it turn out!
Anonymous
  • Posted on Mar 11, 2010
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
People if you can fix your tvs thats great! However please understand there is a incredible amount of HIGH VOLTAGE running through any television and if you do not know what your doing it can be fatal. please be careful.
3answers
TV will not turn on. It just clicks.
RELAY is clicking noise you hear.FUSE IS GOOD!!
Power supply problem.
Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Samsung LN-S4051D 40 in. LCD Television will not turn on
Are the red lights still flashing after replacing the caps? Bulging caps usually means the caps are at the end of their life span, but shorted caps may look just fine. Check any caps that you did not replace to see if they are shorted. I bet you still have a bad cap somewhere on the power supply that is shorted.
1helpful
Samsung LCD TV will not turn on or off. Red light
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
2helpful
2answers
MY TV DOESN'T TURN ON....POWER LIGHT BLINKS
power supply board is dead and needs to be replaced. very common problem.
5helpful
3answers
. Clicks back and forth for about 2-4 minutes then comes on
Check capacitors on top right corner of power supply. Mine had two 2200uF 10Volt capacitors bulging at the top, one was leaking. I replaced these and the problem is gone. You can order the capacitors on ebay. Board had two 2200uF 10volt caps and three 1000uF 25volt caps, all in the top right corner.
2helpful
Samsung model LNS4051DX/XAA won't turn on, just clicks
THE PROBLEM IS Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
5helpful
Samsung LNS4051 DX makes clicking sounds but will not turn on.
First, this is not a projection TV.
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced. If you are not comfortable replacing components which means using a soldering iron, you can replace the power circuit board, available from discount-merchant.com.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
