Master
- Posted on Jul 27, 2010
Re: Just updated the software with webupdate for windows...
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
- The GPS device is missing it's unlock code
- The maps on the GPS device have been disabled
To
determine the cause of the message, touch the screen until the message
"No Detailed Maps Found That Support Routing" disappears.
- If
you see a "Can't Unlock Maps" message following this error, remove any
microSD / SD cards in the device and follow the instructions below for
Retrieving your unlock codes followed by the instructions for Creating
an unlock file
- If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
- Log into your myGarmin account
- Select Manage Maps
- Select Details
- The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
- Plug your Garmin device into the USB port
- Double-Click on My Computer or Computer located on the desktop
- Right-Click on the Garmin or nuvi drive
- Click Explore
- Double-Click on the Garmin folder
- Right-Click in a blank space in this window
- Move your mouse over the word New
- Select Text Document
- Press Enter / Return on your keyboard
- Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
- Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
- Select File
- Select Save As
- Change the Save As Type to All Files
- Type gmapprom.unl in all lower-case letters for the File name
- Select Save
- Close the Notepad window
- Delete the New Text Document file
- Disconnect the GPS device from your computer
To check that the map has not been disabled. Press Tools, then press
Settings, then press Map, then press Map Info and see if your map has a
tick to show it's selected. If not press the map name to select it. It
should then work.
