Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
    New Friend:
Just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Posted on Jun 08, 2012
    New Friend:
My mtd 600 series riding mower will not disengage blades. blades are always on even with deck up
Posted on Sep 05, 2010
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
Release blade engagement attachment lever craftsman #917259330
there sure be a lever to disengage on the fir =e wall of the lawn mower deck or near fire wall o the lawn mower
Oct 16, 2014 | Garden
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Jul 03, 2010 | Craftsman Garden
Yth2448 riding lawnmower blades will not disengage
My craftsman lawn mower will not engage the blades
Jun 08, 2010 | Husqvarna Garden
Blades disengage when they are suppose to engage
Sounds like a faulty switch? This scenario doesnt really make sense. Sorry. Please explain more clearly. Thanks, Mike. Rate 100% please.
Jul 04, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
2,474 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
