are you connecting your computer to your tv using an extended desktop through your computer?
One bad lead can cause a computer to continue on a cycle
or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make
sure they have a secure connection and are not faulty or just replace them
there probably old and faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they
could be faulty a computer needs its connections to continue its cycle and to
have an end so any faulty leads will end up with a computer error
also
click start control panel,display,desktop you can select a different
desktop from the drop down list
or a browse button where you can select different pictures
this may vary depending on your operating system
also settings you can
change the settings for more or less pixels or from the drop down list pick the
appropriate level of color range or troubleshoot also select advanced then
general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
First, click to open the Computer, on your "Desktop Screen"
or click on the "Start Button.
In the (right, shortcut menu), select to open the Computer, by {right} clicking on it.
Check to see if there's a External Hard Drive 'letter ie; [F:] ?
In the [Device Manager]; check to see: if there is a [Disk Drive] Icon?
!Attention: If 'problem still exist?
{Start Button -> All Programs -> Accessories -> System Tools -> System Restore}
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!" paul7of9
unfortunately its over d warranty period...
n d problem is that i hav a lot of data stored on it..
Wat amazes me is that d pc recognizes d presence of an external drive but it does not show any of d data...or capacity of d HD..
If that is smth which can b fixed, feel free to give me any kind of advice, cuz at d present moment i got my hands tied...
