Expert
- Posted on Sep 18, 2010
Re: Vaio sat survey not working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
- Open the run window by pressing the "Windows" and the "R" Keys.
- Then, in the run window, please type "msconfig".
- This will open the "System Configuration Utility" window.
- In the System Configuration Utility window, please click the "Startup" tab.
- In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
- Then, please remove the check mark next to the above items.
- Then, please click the "Apply" and "OK" buttons.
- The Computer will prompt to restart.
- Please restart the Computer.
- The error message should not be there when you restart the Computer.
