Issue
The
printer is working, but the colors in the printed output are not the
expected colors. The output may look as if only one color has printed,
or as if a color has not printed, or as if the wrong colors have been
printed.
Solution
Complete the following steps to resolve this issue.
Step one: Check ink levels
If
the print defect is minor, it might be caused by reserve mode
operation. When the printer runs out of some colors, it can continue
printing using remaining inks, but print quality may be affected. If
cyan, magenta, or yellow is out, the printer can print only in
grayscale.
NOTE:
HP
cannot guarantee the quality or reliability of non-HP ink. If ink
cartridges have been refilled, try replacing them with genuine HP ink
cartridges.
Replace any empty print cartridges.
To access the ink level gauge, follow these steps.
Press
Setup
Press
to select Tools
, then press
OK
Select
Display Ink Gauge
and press
OK
. The ink levels are displayed.
Figure 1: Ink levels
Each
icon corresponds to the cartridge that is the color of the icon. The
icons are also in the same order, from left to right, as the cartridges
in the printer.
If an icon is empty, the corresponding cartridge may need to be replaced soon.
The
ink levels in non-HP, refilled, and remanufactured cartridges cannot be
read by the printer. Instead of an icon, a question mark is displayed
for these cartridges. HP cannot guarantee the quality or reliability of
non-HP ink. Printer
service or repairs required as a result of printer failure or damage
attributable to the use of non-HP ink will not be covered under
warranty.
Step two: Calibrate the color
If the cartridges have not been refilled and none are empty, try calibrating the color.
Open the printer
Toolbox
Open
HP Solution Center
(click
Start
, then
All Programs
, then
HP
, then
HP Solution Center
If you have more than one printer installed, make sure to select the correct printer tab in
HP Solution Center
Click
Settings
Click
Print Settings
Click
Printer Toolbox
On the
Device Services
tab, click
Calibrate Color
, then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead
If the steps above did not help, clean the printhead.
Open the All-in-One
Toolbox
Open
HP Solution Center
(click
Start
, click
All Programs
, click
HP
, and then click
HP Solution Center
If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in
HP Solution Center
Click
Settings
Click
Print Settings
Click
Printer Toolbox
On the
Device Services
tab, click
Clean the Print Cartridges
, and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP
If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
