SOURCE: Whirlpool DU1145XTPPB7
These dishwashers normally have a "Control Lock" mode. It's in the manual. It is provided for child safety. It's often controlled by holding the "No Heat Dry" button for 4 seconds or more -- same procedure turns it on or off.
SOURCE: I have a whirlpool gold
Hi If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry .
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an
issue with the wash pump not pumping the water past the heater efficiently or
due to lack of water to heat. Please make sure that heater is not open
circuited and is heating the water efficiently. You'll have to check the heater
using a multimeter; the meter should read between 3000 to 3300 ohms (Use
multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure
is optimum and fill valve is working fine. Hope this helps... Please post
back if you need more information. Daniel
SOURCE: Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
I had the same symptoms and the front panel was the fix
the part with the buttons on it
Hi
If light is blinking then it may be an
issue with heater circuit, door switch or the thermal fuse, please reset the power to
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry.
issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post
Daniel
Hi
Daniel
Hi
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
Hi
If clean light is blinking 7 times then it may
be an issue with heater circuit, door switch or wash pump. If yes then please
reset the power to the dishwasher. After, 5 minutes check if you are still
getting the same error. If yes, then it is a water heating fault. To resolve
this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry -
Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy
saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3
minutes and then you press the Cancel/Drain button and allow it to completely
drain and reset. If this doesn't work then it's an issue with the wash pump not
pumping the water past the heater efficiently or due to lack of water to heat.
Please make sure that heater is not open circuited and is heating the water
efficiently. You'll have to check the heater using a multimeter; the meter
should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If
heater is fine then make sure water pressure is optimum and fill valve is
working fine. Hope this helps... Please post back if you need more
information.
Daniel
