If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
SOURCE: panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
SOURCE: Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
